how did I miss that in Blender. Thank you very much
I always wanted my Modo back. I always had "toggle X-Ray" enabled and went to Shaded Mode to do get a reliable Selection. Selecting by "Face Center point" and made me nuts. I hope it can select also occluded Faces .....
EDIT : OK, not in Edit Mode. At least it works in Object Mode ....
Thank you very much !
I wasn't aware of Blenders Filter (Sub) Options in Outliner .....
So far I think choosing "Selected" does help to work with crowded Files
(If it does not negatively interfere elsewhere ... So far I all time moved cursor over Outliner and pressed NumComma to find my selected Object in Outliner)
But did I get that correct that your tool eliminates the need to switch to/between Editing Modes ?
(Selecting Objects/Faces/Edges/Vertices at a time ?)
That would be super cool.
I was used to such perfect Mesh Selection options in Modo in the past and now still suffer from Blender's missing select-through control or its Face-Center-Point.
This 'is' the Cross Select code integrated into Bonsai. It's basically turned on with all Bonsai tools, so you don't have to specifically initiate the Cross-Select tool... it's always on.
Oh man, that's awesome! Thanks for sharing!
I vote this should be default in BB! :)
Oh my God ...
might interest you...
https://community.osarch.org/discussion/3109/a-small-plugin-to-move-the-cursor-to-center-of-mass-and-or-bounding-box/p1
actually, it does work in Edit mode, scroll down the T-panel and you'll see the Icon
Interesting, didn't know I have to/can activate it.
When activated, it works like a charm and I get colored Marquee fences - Great.
Very good! Missing in action!
My cent, this demo
Used AI to integrate the cross-select functionality natively to Bonsai...
https://github.com/IfcOpenShell/IfcOpenShell/pull/8153
Great.
I have already a similar AddOn for Blender :
https://extensions.blender.org/add-ons/cross-select/?utm_source=blender-5.2.0-lts-beta
To make Blender a bit more (CAD) industry conform.
