Creating and Assigning Tags
@Moult Dion is it possible to create new tags for the threads? For example a Structural Analysis
would be needed. It seems I can only use the existing ones, which should be the most popular. When writing a new tag in the dedicated place, it enters into search mode only, so no way to create a new one, unless I am missing something.
Type the tag you'd like, then press enter? That works for me.
Yes I ve been doing this but does not work, tried from desktop and my cell phone as well. It seems like I am in search mode between the tags available and it does not accept new tags.
Hmm, you're an admin so you should have all the same rights that I do. Feel free to ping me on IRC and screenshare. At the very least you can add a tag via the admin dashboard.
Ok I will write in IRC
@Jesusbill did you get this to work? I've also not been able to make this work. Until we have lots of tags and need tidying up I think we need everyone to be able to create their own tags.
@duncan No not yet, I still didn't talk to Dion in IRC
@Jesusbill try now, it works for me. I've given everyone in the members, moderator & admin roles access to add new tags. Otherwise see https://community.osarch.org/settings/tagging Remember that it is only possible for the first post in any discussion. This type of setting is here: https://community.osarch.org/dashboard/role
@duncan Yes!! Now it works! Thanks!!
