Learning Material for Code_Aster and Salome_Meca
I am providing a non-exhaustive list of learning material for whoever interested in using Code_Aster and Salome_Meca.
Please, feel free to add any additional material you may know of, thanks.
The BOOK - or the BIBLE for many of the existing users
This book by Jean-Pierre Aubry, one of the gurus and super-users of code_aster, is perhaps the must-read material for anyone wanting to start, especially structural engineers with focus on 1D (beams, columns, trusses, cables) and 2D (walls, slabs) analytical elements.
His pre- and post-processing workflow is based on Gmsh, outside thus the Salome_Meca ecosystem, a choice which I respect but not fully embrace, nonetheless the material presented for creating the so-called "command file" that drives the code_aster analyses is invalueble.
Video Tutorials
Youtube channel of Cyprien Rusu
Youtube channel of Aether Engineering
- Code_Aster Tutorials playlist
- How-to Videos with Code_Aster playlist
- GitHub Repository code-aster-examples with all related files from the above referenced videos
Youtube channel of Digvijay Patankar
- Code_Aster/Salome-Meca playlist
Youtube channel of CAEforALL
- SALOME_MECA Tutorials playlist
Youtube channel of opensource cae
- Code-Aster tutorials playlist
Youtube channel of code aster
Youtube channel of FEAnalysis
Official Documentation and Code_Aster Forum
Code_Aster has perhaps one of the most extensive list of documentation and validation cases. The downside is that documentation is written in French and then machine-translated to English, which can be a bit clumsy at times. In any case, for a correct reference of the commands to be written in a command file I always recommend double-checking with the French version, other than that the English version is fine in most cases for reading.
Documentation for stable v14 version. Contains:
- U(tilisation) documents that explain each available command
- R(eference) documents that explain the theoretical basis of the code
- V(alidation) documents that summarize the validation cases - along with an explicit list of all testcases by name
You can watch this video to see a bit about the documentation and how to access and run all testcases inside Salome_Meca. All testcases are also included in the installed folder of Salome_Meca (.../V201xxxxx/tools/Code_aster_xxxx/share/aster/tests)
Official training material from Code_Aster's website
Code_Aster in Italy - mostly for who speaks Italian :)
- The website of the Italian community of Code_Aster.
- Documentation in Italian
This is really great stuff! Perhaps it should be published on the wiki?
Yes I guess you are right, will do that as well
Not sure how to add a new page thought that will be referenced in the main page.
[Edit] Nevermind, I got it
Done 👍
