BlenderBIM Add-on new release!
1568101113
  • edited August 2021
    @Ace said:
    @MexiKiwiMike
    There is also a little test library of elements that makes starting quicker,
    It's super quick once you know the hotkeys and the walls are loaded:
    Click -> load IFC library (below create IFC project) -> once loaded click the paper clip on the right to load each element
    how about this blenderbim-demo-library.ifc files. Lot of viewer do not display them. The one I use very often even crashes. I came around these files here ... https://community.osarch.org/discussion/comment/8524/#Comment_8524
    Are there any more information available? May be at the wiki or at buildingSMART?
    cheers bernd
  • @bernd that file is not meant to be displayed by a viewer - it is a partial file containing only library data, but no project. To be legal (and thus viewable) I guess I need to wrap it in a project, even if it seems redundant.
    Thanks for bringing this to my attention, I thought I had once seen libraries used by themselves by an official buildingSMART example but I cannot find it now, and only find evidence that libraries can only exist wrapped in a project. Perhaps @geometrygym might know?
    bernd
    I relized myself the missing of the IfcProject. Since it has ifc file ending we need to do something in this regard (IMHO). If it has ifc file ending people will try to open it in a ifc viewer and will fail. The viewer could even crash. Viewer developer might say BlenderBIM does create non standard ifc. We should not let this happen.
    Neverless I like the idea to use ifc to save libray data.
  • Hi Dion, you're probably referring to a geometry gym sample that isn't compliant with the specification. At present the IfcProject is a mandatory singular concept in an IFC serialization. Perhaps this could be relaxed to be an IfcContext (supertype of IfcProject and IfcProjectLibrary) but at present the library needs to be declared by an IfcProject to be legal. It would need a schema change but also some working groups have explored ifc "snippets" which are isolated IFC data sets not necessarily in context.
  • But the real Rabbit (i.e. the one in all the photos) is my cute female pet bunny named Cinnamon. She can do tricks and her portfolio is here.
    Bet she speaks Python!
  • @bernd @geometrygym cheers, I've now fixed it. https://github.com/IfcOpenShell/IfcOpenShell/commit/a1b462a83b1b795addf77951533a54ab5140e1b2
    I still need to build a bunch of project library editing related UI - so that it shows up in the tree, and you can manage multiple library declaration (right now, only a single library declaration works). But at least it is legal now :)
    bernd
  • Hi, I need help with the file “blenderbim-demo-library.ifc”. When loading in “IFC Project Library”
    I’m getting an error message: “Ifcopenshell.Error: Unable to parse IFC SPF header”
    Thanks in advance!
  • No love for M1?
  • @Carozo it sounds like you have not downloaded the library file correctly. Try file save as from this page: https://raw.githubusercontent.com/IfcOpenShell/IfcOpenShell/v0.6.0/src/blenderbim/libraries/blenderbim-demo-library.ifc
    @VDobranov not at the moment, no, we don't build for ARM. Would you mind posting at https://github.com/IfcOpenShell/IfcOpenShell/issues/1702 ? I think to solve it, we need to purchase an ARM MacOS machine. Perhaps we could fundraise for this?
    Just to try the waters: are there any means to donate on particular goal?
  • @VDobranov not to a particular goal, sorry. But donation in general is supported at https://liberapay.com/dionmoult or https://opencollective.com/opensourcebim
  • edited October 2021
    BlenderBIM Add-on v0.0.211031 has been released with 187 new features and fixes. It's our built environment, help support the BlenderBIM Add-on: 100% free and open source software that lets you author and document BIM data fully to ISO standards. It's built by the AEC community, for the AEC community. Get it today: https://blenderbim.org/
    Let's get into the details.
    Upgrade to IfcOpenShell v0.7.0, for a 35% - 2,000% (yes!) speed boost and new developer toys
    The biggest aspect of this release, which is why we delayed it for a month, was an upgrade to v0.7.0 of IfcOpenShell. This represents a significant impact for developers, thanks to the tireless efforts by aothms. We will now benefit from geometry caching (in future releases), a new drawing generator (WIP), a huge speed boost ranging from 35% to 20 times faster depending on what you're doing, visualise bounding boxes and fill areas, SVG analysis, and version tags. Users can start to play with the ongoing drawing features in upcoming daily builds, and generally see things faster everywhere.
    New testable code architecture
    On the Python side, code has been rearchitected to allow for a more robust test framework and UI rendering. For developers, this represents a maturation of the codebase and developer community, including code standards for licensing, QA, style (black), linting, and TDD. Over 800 tests were written for this release with the new architecture, spanning from unit tests to full integration tests. For users, this is largely responsible for the staggering 68 bugs zapped during this release, so users will likely notice less regressions, and that the BlenderBIM Add-on will start feeling more and more like a native authoring tool.
    Partial project loading support
    You no longer need to load an entire project. By enabling advanced mode when importing, you can filter what you want to import, allowing you to load huuuge models much faster and only related to what you're planning to edit or review. Choose from filtering by location or by type, as well as new collection hierarchies.
    Parametric geometry is now default
    One of the biggest user impacts when editing is now that parametric geometry is default. You can now push and pull things as a mesh, but under the hood the parametric geometry will be preserved when possible. This leads to much more natural modeling and less paying attention to geometry modes and updating representations. This feature is also a leap of faith in standardised parametric IFC geometry, so keep an eye out for issues!
    Improved construction scheduling
    Construction scheduling continues to improve with bugs fixed around date calculations, rendering animations, real time date visualisation, Primavera P6 XER and resource import support, a new Ifc4D command line tool, improved formwork calculations, and more.
    So much more
    Other notable improvements include more point cloud support, user UI presets, real time type filter, bulk property and attribute editing, a few MEP system visualisation tools, and upgrades to the ownership and context editing modules. A huge thanks to the growing volume of new contributors who are joining the team and changing the industry. You can too!
    jchkochCyrilbrunopostlebitacovirbasweinchunchktheoryshawpaulleeDarth_BlenderMeetlatand 14 others.
  • All changes
    New features:
    • We now support importing 3D annotations, not just 2D ones. Neat.
    • Invalid annotation contexts coming from Revit are now accepted
    • IfcOpenShell validation now handles logical data types. Thanks rbertucat!
    • New feature to draw system arrows showing flow direction and port connections.
    • New MEP utility to select and print debug information about connected system elements
    • Importing resources for XER and XML files from P6 is now supported. Thanks HassanEmam!
    • Optimistically track all object edits whenever you toggle edit mode, not just meshes. Let's see how this goes.
    • Optimise owner check depending on your implementation and no longer create default users on IFC4. Can result in 50% faster script running on long scripted operations like imports.
    • You can now manually type in start/end dates for construction sequence visualisation instead of clicking the date picker hundreds of times.
    • New UI "persona" presets in preferences. Thanks vulevukusej!
    • Moving grid axes are now synchronised automatically
    • Resize object to storey now works for a variable number of storeys
    • Adding annotation now auto enables viewport decoration drawing.
    • First pass at connecting to new ifcopenshell.draw for drawing generation.
    • New hacktastic IFC patch to fix ArchiCAD spaces being loaded into Revit.
    • You can now split objects using a drawn edge, especially useful when creating slab pour breaks and fixing lazily modeled walls and columns. Thanks Gorgious56!
    • Ifc4D XER import now supports calendars. Thanks HassanEmam!
    • New feature to calculate side formwork, such as for columns.
    • Formwork area calculation now unions objects before remeshing to account for overlapping geometry
    • Types in type dropdowns are now sorted alphabetically for convenience.
    • Spatial elements in the import filter will now be sorted by elevation for convenience.
    • Users copying and pasting via ctrl-c/v will now also copy IFC objects.
    • Using duplicate move linked in a BIM project now also triggers IFC copying
    • BlenderBIM: import IFC PointCloud Representation support. Thanks LaurensJN!
    • Support for importing Primavera XER files for construction scheduling. Thanks HassanEmam!
    • Added IfcTypeFilter feature into BlenderBIM Search module. Thanks chunchk!
    • New feature to show inherited element type psets.
    • Get psets utility now supports getting material and profile psets
    • Get psets utility can now filter only psets or qtos
    • Element get_psets utility now returns the pset ID for convenience.
    • New feature to copy properties from one object to all selected objects
    • Reintroduced feature to copy attributes to selected objects.
    • You can now toggle module visibility to customise your UI. Thanks vulevukusej!
    • Copying parametric geometry from any source now attempts to preserve parametric geometry when possible.
    • Assigning a parametric layer type (for walls for now) now attempts to switch from non parametric to parametric geometry.
    • New feature to conveniently add a default material in a blank project when none exists.
    • The type of mapped representations is now shown in the interface, with an asterisk denoting it is mapped.
    • When updating representations, the existing representation type is prioritised unless you tell it otherwise.
    • Assigning a parametric profile type now auto switches from non parametric geometry to parametric geometry
    • Only show type selection buttons when a type is available.
    • New feature to calculate the radius of a polygonal circle
    • Upgrade to IfcOpenShell v0.7.0. Thanks aothms!
    • New Ifc4D command line interface. Thanks HassanEmam!
    • Adding type empties now adds it to the scene collection for convenience in case your types collection is hidden (which is most of the time)
    • New feature to add psets to all selected objects. Thanks vulevukusej!
    • Documented UX guidelines. Thanks Gorgious56!
    • Documented MacOS build instructions. Thanks m-clare!
    • When assigning types, your preference of dynamic voids are now preserved.
    • IfcOpenShell now supports geometry caching. Thanks aothms!
    • New feature to resize / squash / stretch objects to their storey height. Useful for remodeling IFCs for construction simulations.
    • New utility function to get storey elevations with elevation attribute fallback for more compliant sorting of building storey elevations.
    • Unlinking an object now also unlinks materials and styles too for convenience.
    • New feature to unlink Blender materials and IFC materials
    • Spatial containers are now shown sorted by Z index order for convenience.
    • Building storeys now show a derived storey height so you don't need to do math
    • You can now copy a representation from one object to another
    • FMHEM classes now updated to latest draft
    ... continued ...
    jchkochCyrilbitacovirbasweinJesusbillCoenhtlcnnengfernando
  • ... continued ...
    • You can now toggle whether element filtering also affects spatial containers
    • Implemented point cloud export function. Thanks LaurensJN!
    • Use context filters during import when possible to optimise import times
    • New support for conversion based units with offsets, like fahrenheit.
    • Support auto detection of unit type when adding imperial units
    • Utility to print out all maintainable assets for FM paper documentation
    • New recipe (and essay) to fix ArchiCAD IFC4 door swings showing up in Revit
    • IfcCSV now supports setting properties to null values. Neat.
    • IfcCSV now supports editing properties that were previously null.
    • Add tooltips to the authoring panel. Thanks maxfb87!
    • You can now clear the active user for ownership history.
    • New usecase for adding conversion based units
    • You can now import and export and clear all IfcCSV attributes. Thanks vulevukusej!
    • Prioritise editing rendering surface styles over shading surface styles
    • New unassign aggregate feature.
    • Spatial containment now distinguishes between direct and indirect containment
    • Removing or changing spatial containers now supports updating more types of collection organisations
    • Maintain active object throughout complex IFC operations for a better user experience
    • Place structural items in collections for new project. Thanks Jesusbill!
    • Fix for structural surface items. Thanks Jesusbill!
    • Allow user to toggle duplicates when getting inverses in IfcOpenShell core.
    • You can now add and remove users for ownership history
    • Optimise create owner history to not rely on a person and organisation lookup, speeding up long procedures
    • Application data in IFC now reflects the latest IFC version tag
    • Removing contexts now also reassign to parent or remove references to the context.
    • You can now edit attributes of contexts and subcontexts.
    • Organisations now support null attributes.
    • Add support for null attributes for people, roles, and addresses.
    • Prevent using pset operators when no template available. Thanks Gorgious56!
    • Remove need for IfcConvert since we can drawing is now part of v0.7.0.
    • Improve UX by blocking the user from creating sub resources under a subcontract resource.
    • Add support for IfcBoundingBox visualisation.
    • New IfcOpenShell context ID filter.
    • Add support for IfcAnnotationFillArea.
    • New support for specifying collection modes.
    • Spatial elements now support 2D representations.
    • Generated construction visibility now works in renders, not just viewport view.
    • Improve UX where active object was swapped when adding voids. Thanks Gorgious56!
    • New feature to see the current frame's real life date as text during a generated animation
    • Editing psets can now accept user specified data types and auto-detect non-string data types
    • Be more accommodating when fetching properties to allow for users writing incomplete scripts.
    • Resource work duration can now be calculated based on counting produced products.
    • Resource work durations can now be calculated either daily or hourly
    • Optimise update owner history to speed up complex operations
    • Add support for specifying placement matrixes in project units or SI units.
    • New utility to get spatial and object decompositions from any IFC element
    • Create shape debugger now includes time information.
    • Deprecate auto detection of vendor workarounds as no longer necessary.
    • You can now filter imported objects by IFC class when loading a project
    • You can now unload a partially loaded project
    • You can now partially load an IFC filtered by spatial containers.
    • You can now load a project from the project panel.
    • IfcOpenShell SHA is now shown for versioning
    • Deleting openings or voided elements now also remove openings.
    • Non dynamically voided objects now auto update when their opening is removed
    • Assigning an opening now ensures it displays as a wire
    • BIMTester now runs within the BlenderBIM Add-on, implement attribute checking in IDS.
    • Remove create project library ability, as you should create a project first
    • Manual import offsets now apply on object placements for efficiency.
    • Immediately redraw the Library panel on load for improved UX. Thanks Gorgious56!
    • Notify if file already contains library element. Thanks Gorgious56!
    • Improve mesh IFC Representation User Experience. Thanks Gorgious56!
  • New fixes:
    • Objects now sync spatial hierarchy more robustly on export, and clean the collection tree in case the user messed it up.
    • Fix bug where during import sometimes aggregation collections don't match object names
    • Fix bug where imported grids were not linked and didn't auto track edits
    • Fix bug where auto geolocation offset didn't occur if placements were relative
    • Fix bug where copying a type also copied its type relations which is invalid.
    • Fixing bugs for Scheduling Module IFC4D, where P6XML Parser failing on calendar type. Thanks HassanEmam!
    • Fix regression bug where you couldn't add a grid.
    • Fix bug where imported types with representations but no instances were not fully linked.
    • Fix bug where switching to an object with modifiers applied would double the effect of modifiers.
    • Fix bug where large resizing of walls could result in broken geometry.
    • Fix bug where copying elements didn't ensure that material usages were unique
    • Fix terrible bug #1819 where duplicating mapped elements didn't actually copy the geometry mapping.
    • Fix bug where you could reassign class to another product type and create invalid relationships
    • Fix bug where BCF header file info was not loaded. See #1816.
    • Fix geometry bug for some types of IfcIndexedPolyCurve. Thanks aothms!
    • Fix bug with invalid initialization of local variable "data" in bcf. Thanks Nitschi!
    • Fix bug where auto assignment in the collection hierarchy failed if you had filtered out aggregates and you were assigning a subelement of an aggregate
    • Fix bug where you couldn't bulk copy non-geometric elements to other spatial containers
    • Fix bug where when deleting representations it could sometimes overreach and delete geometric, style, or layer data of other elements.
    • Fix bug where copying objects may sometimes result in incorrect location in the Blender collection tree
    • Fix bug where copying objects did not necessarily retain the existing context assignment
    • Fix minor bug where Python warnings showed up when delete operations were called
    • Fix bug where importing multiple assets sharing an already imported material fails.
    • Fix bug where the derived placements interface didn't take into account rotations
    • Fix deep magick bug where copying elements without having one of them active didn't actually copy them in IFC too
    • Fix bug where you couldn't filter imported subelements without also selecting their parents
    • Fix bug where copying elements shared a placement. This fix speeds up copying parent elements in the decomposition significantly, like when copying a storey.
    • Fix bug where copying a container also copied its contents
    • Fix bug where duplicating a collection messes up the collection tree.
    • Unassigning the last unit now cleans up empty unit assignments
    • Changing aggregation now ensures spatial containment is mutually exclusive to prevent invalid IFC data
    • Assigning aggregations now protects against various invalid aggregation combinations
    • When assigning containers, ensure aggregates and containers are mutually exclusive
    • Fix bug where assigning a spatial container didn't work with non local placements
    • Changing spatial container now guards against invalid containment operations
    • Unlinking elements is now a bit more stable.
    • Upon element removal, empty aggregates prioritise null if possible. Fixes a variety of invalid IFC bugs.
    • Fix bug where removing addresses and roles could leave other elements in invalid states
    • Fix bug. Removing an organisation now properly handles references appropriately.
    • Fix bug where removing a person no longer has the potential to leave files in an invalid state.
    • Fix bug where 2D contexts were not created with the right dimensionality.
    • Fix bug where you could accidentally add a context other than what you selected in the UI
    • Fix possible invalid scenarios when adding fillings. Thanks Gorgious56!
    • Fix error when displaying a selected but inactive object's properties with the pin feature. Thanks Gorgious56!
    • Fix error when filling has no IFC type. Thanks Gorgious56!
    • Fix bug where you could add a filling twice or to multiple openings.
    • Fix bug where you could add an opening twice to the same element.
    • Fix bug where copying an opening didn't copy relevant boolean modifiers too.
    • Fix bug where copying a filled opening would create an invalid relationship
    • Fix bug where structural member data was not updated correctly.
    • Fix bug where demolition animations were not generated properly.
    • Fix bug where nested task resource-based durations failed to calculate
    • Fix task duration calculation bug where hourly work greater or equal to 24 hours were incorrectly parsed
    • Parametric object gizmo scale now follows scene unit, and fix miles and thou-inch units. Thanks Gorgious56!
    • Fix bug where assigning a new container would shift object placements incorrectly due to SI unit conversion
    • Fix bug when shifting object placements and their children.
    • Fix bug where IFC patch didn't work on case insensitive file extensions
    • Fix bug where filtering did not work for indirectly spatially contained elements
    • Fix bug where aggregates break with filtered elements during import.
    • Fix bug where editing styles didn't work if factors were stored instead of RGB colours
    • Fix bug where openings were not unlinked or renamed if they were removed from a non-dynamic object
    • Fix bug where removing an opening might remove an element twice
    • Fix bug where project libraries were not legal.
    • Add transaction support for adding elements. This fixes a variety of undo bugs.
    • Fix bug where project library browser could self reference.
    • Fix bug where element replacement would sometimes fail leading to various problems.
    • Fix typo in material style assignment code. Thanks Gorgious56!
    • Fix bug when copying objects, don't copy their decomposition to prevent invalid IFCs.
    jchkochCyrilbrunopostlebitacovirCadGiruDarth_BlenderMassimoCoenArEhsanChtlcnnand 2 others.
  • edited November 2021
    @Moult : Do you know if blenderbim has been tested with the real-time collaborative addons Mixer or Multi-User for blender? It would be awesome if they can be combined in order to get real-time IFC-editing and engineering capability for multiple users using blender. See this post for info on them.
    BenSmith
  • edited December 2021
    Hi, I have an issue setting up BlenderBIM. I am using Blender 3.0 so that could be causing the issue.
    I tried following Dion's quick demo but I don't have any of the circled options
    I do have BlenderBIM checked in addons and I do have the IFC Derived Placements option, so it seems that BlenderBIM is installed. Any ideas?
    EDIT: Seems I missed the create IFCProject step, it's solved now
  • @HaukMorten unfortunately those real-time collaborative add-ons work only with Blender, but there's a missing step to get it to synchronise with IFC edits. So without testing, I can tell you that out of the box it won't work (yet).
  • Thank you for your response @Moult . Well, it's a wish for later then. BlenderBIM still isn't mature enough for us to use in a production environment yet in either case, but perhaps some day in the not too distant future I can wish for some development funding internally to try to at least figure out what needs to be in place for us to begin to use in for engineering. I've already used it for geometry editing of IFC's that wouldn't open i Revit at all. Once one gets the hang the shortcuts, editing in blender is so much smoother than in Revit!
    Coen
    I've tested all the collaboration add-ons I could find and none of them completely support even the standard Blender functions, let alone any add ons.
    AceMoult
  • BlenderBIM Add-on v0.0.220130 has been released with 252 new features and fixes. It's our built environment, help support the BlenderBIM Add-on: 100% free and open source software that lets you author and document BIM data fully to ISO standards. It's built by the AEC community, for the AEC community. Get it today: https://blenderbim.org/
    It's been 3 months since the last release. Unfortunately, development had been put intermittently on hold due to various factors, including presentations being prepared for the Boao Forum for Asia ISTIF conference, FOSDEM 2022, and the 1-month online course on OpenBIM and Python programming by E-Zigurat. In addition, there was a one month break from development during the holiday period. It's a marathon, not a sprint! :) Happy 2022, and we're back!
    Optimisations to authoring and geometry caching
    A huge kudos to the exceptional optimisation work by Thomas Krijnen. Especially when modifying large files, expect operations to be in the scale of 100x faster, especially when dealing with proprietary BIM exports. Bulk movement checks are a minimum of 5 seconds faster. Importing files with booleans can be 2x to 3x faster. New performance logging in the core means that optimising is far from over.
    A new geometry cache is now implemented, so reopening the same project will be much faster.
    Increased stability
    Native authoring stability was a huge priority for this release. An additional 450 tests were written since the last release, and 76 bugs were fixed. This is the return on investment in the new testable code architecture which was revealed in the previous release.
    Brickschema integration
    Brickschema is a way of describing system topologies for building management systems (BMS). When we talk about digital twins and clear away the marketing buzzwords, we're really talking about things like Brickschema and live building sensor data that Brickschema can reference. The BlenderBIM Add-on is the first in the industry to start providing a graphical Brickschema authoring environment that integrates with IFC.
    It is now possible to create a 2-way link between IFC BIM models and Brickschema BMS models. This is possible due to new support for managing IFC libraries. Brickschema authoring is still very new, but it's ready for basic testing!
    New bulk property editor
    In our quest to help clean OpenBIM data in the industry, an incredibly suite of bulk property editing tools are now available by developer Vukas Pajic. Includes bulk renaming, data type changing, removal, and adding properties.
    Chipping away at drawing generation and MEP support
    Drawing generation is a huge task that still isn't ready for user testing, but all the same work has been done. Including improved section cutting booleans, geometry caching, fixing "the torus problem" for steel sections, new 2D elements in the demo library, paper scale annotations in the viewport, performance testing, native IFC roundtripping for annotations, associating objects for smart annotations, annotation variables, drawing sheets, and improved UI.
    Also ... more rabbits!
    MEP is one of the areas not really supported by the BlenderBIM Add-on but that is now changing. Support is now added for different types of building systems, selecting different types of systems, and displaying distribution ports.
    Better docs and building for developers
    A number of fixes to the build system makes life easier for developers on different environments to build IfcOpenShell thanks to Thomas Krijnen. Also really exciting is the new super secret demo module tutorial and improved developer guide for new developers who want to learn how to build your own BIM application on Blender and extend the BlenderBIM Add-on.
    So much more
    Other notable improvements include new UI grouping, IFC to P6 XML export support thanks to developer myoualid, viewing IFC metadata prior to loading with one-click IFC4 file upgrades thanks to developer Gorgious56. Blender 3.0 is now officially supported. In addition, new support for parsing EXPRESS schemas in the interface has been added, in preparation to support IFC4X3. The testing process for IFC4X3 support has begun, with the hundreds of tests in the suite being redirected to check IFC4X3 support, with very promising initial results.
    MassimovpajicGorgiousAcebitacovirthunderbolt_132brunopostletlangNigelbasweinand 8 others.
  • All changes
    New features:
    • IFC element names no longer treat the Blender name suffix as significant
    • Object names now guard against duplicate IFC prefixes when assigning.
    • All element's spatial containment collections are now synced when assigning a class.
    • Structural items in the collection hierarchy are now auto synced.
    • Remove legacy unassign class feature in favour of just deleting objects. Thanks theoryshaw!
    • #1692 get_info_2() logical now supported Thanks Thomas Krijnen!
    • You can now specify a target view when creating a new drawing. See #1153.
    • Drawing collection hierarchy is now auto fixed if shuffled around manually. See #1153.
    • Drawings list now reads data from IFC, not Blender. See #1153.
    • Removing sheets now works in IFC. See #1153.
    • You can now create drawing sheets in IFC. See #1153.
    • You can now show and hide distribution ports of an element.
    • New diagrams on the developer guide.
    • Finish building minimum viable product of the IFC2P6 converter. Thanks myoualid!
    • Fix #1514. You can now customise the default names of occurrences create from a type.
    • New software architecture section in the developer guide.
    • New demo module to teach developers how to hack on the BlenderBIM Add-on.
    • Updates to space boundary geometry now auto updates on export.
    • IfcCSV now loads the selector by default so its much more fun to use a lib.
    • You can now remove bricks from a Brickschema model.
    • New utility function for getting ports of an element
    • Implement assign and unassign ports in IfcOpenShell API
    • Dynamically update section shader backface color (#2000) Thanks Gorgious56!
    • Nodes are now offset nicely for cutaway shader (#2000) Thanks Gorgious56!
    • Smart annotation variables for drawings now reimplemented. See #1153.
    • #1993 vs2022 hdf5 Thanks aothms!
    • Editing task times no longer tries to be clever with actual dates because you know what you're doing.
    • Fix #1576. Managing IfcSystem subtypes is now possible.
    • #1993 msvc 2022 config Thanks Thomas Krijnen!
    • Nicer looking gantt charts and make it easier to print to PDF.
    • Code licensing clarifications. See #1082.
    • Fix #1908. Extracting elements using IfcPatch now includes all properties.
    • Fix #1962. You can now easily append product assets using the API.
    • You can now reset and restore your API owner settings.
    • Header data previews for IFCZIP are now supported as well.
    • Fix #1956. One-button upgrade from IFC2X3 to IFC4.
    • Minor improvement to the sequence UI to always allow you to cancel editing mode.
    • ADD_COMMIT_SHA in build scripts Thanks Thomas Krijnen!
    • You can now associate annotations with objects for smart annotations in IFC. See #1153.
    • define the vector sass [0] as a std::vector<std::unique_ptr> Thanks Benjamin Dahl!
    • Remove broken and obsolete Blender clasher which is incompatible with the geom.tree broadphase approach.
    • Improvements to 2D booleaning Thanks Thomas Krijnen!
    • Implement adding plain bricks not based on IFC
    • Support type-based class checking for converting IFC2X3 models to Brickschema
    • The IFC Class panel now shows inherited predefined types
    • New utility to get predefined type
    • Show ifc specs in file selector (#1980) Thanks Gorgious56!
    • UI Simplification with Panel Groups (#1979) Thanks Vukas Pajic!
    • Implement auto and manual refresh of the Brick model navigator
    • You can now create a new blank Brick project
    • New debug feature to purge HDF5 cache in case the cache is corrupted.
    • Implement human readable rdfs labels in Brickschema navigator
    • Display IFC schema in file selector right hand side panel (#1978) Thanks Gorgious56!
    • New utility to get IFC all elements that are relevant in Brickschema
    • Basic implementation to bulk convert relevant IFC classes to a Brick model
    • New IFC to Brick class mapping utility
    • You can now select all system objects from the object panel for convenience.
    • Optimise all editing API functions to be 100x faster when you're dealing with proprietary BIM exports with loads of shared owner histories. See #1904 and #1905.
    • Schema versions are no longer locked to IFC4 and 2X3. You can now load express schemas at run time.
    • Purge obsolete IFC types mappings
    • Install to system local root Thanks Thomas Krijnen!
    • Fix: shift count negative or too big Thanks Thomas Krijnen!
    • #1960 BRepBuilderAPI_MakeFace on non-overlapping 2d subtraction Thanks Thomas Krijnen!
    • Log performance aggregates as logger messages Thanks Thomas Krijnen!
    • Logging statement for total file conversion Thanks Thomas Krijnen!
    • Update template.py main.schema_identifier doesn't exist Thanks Thomas Krijnen!
    • #1969 take uppercase in register_schema() Thanks Thomas Krijnen!
    • build-deps.cmd typo 0.7.0 branch Thanks jakob-beetz!
    • The IfcOpenShell API now supports automatic primitive casting for editing properties. See #1943.
    • Primary measure type lists are now dynamically generated based on the schema.
    • Write documentation to help developers get acquainted with testing
    • fix umlauts not showing up correctly in dynamic enums #1941 (#1945) Thanks Vukas Pajic!
    • Fix #1717 : Disable task editing if task was deleted as a result of deleting its parent (#1936) Thanks Gorgious56!
    • Optimize logic for bigger number of tasks (#1936) Thanks Gorgious56!
    • New bulk property editor (#1896) Thanks Vukas Pajic!
    • Updated README.md for IfcOpenShell build instructions Thanks ssg! Thanks garylzimmer!
    • BlenderBIM Feature - Filter By Building Storey Thanks bosonprojets!
    • Good news everyone! Option to process wall opening subtractions in 2D. Thanks Thomas Krijnen!
    • Small changes to iterator settings Thanks Thomas Krijnen!
    • changes in ifc2ca standard case Thanks Jesusbill!
    • ifc2ca - possibility to exclude zero length springs in point connections Thanks Jesusbill!
    • changes in ifc2ca bonded case Thanks Jesusbill!
    • Optimise operations on large files. #1807 method mapping proposal Thanks Thomas Krijnen!
    • minor changes in ifc2ca scripts Thanks Jesusbill!
    • OCC7.5 to OCC7.6 support -> deprecated Poly_Triangulation Nodes() Thanks fichter!
    • Switch to libocct for yml workflows Thanks Thomas Krijnen!
    • Prevent searching for invalid IDs in IFC debugger (#1924) Thanks Gorgious56!
    • New descriptions, labels, and debug output in IFC debugger (#1924) Thanks Gorgious56!
    • Debug op to select highest meshes by polygon percentile (#1924) Thanks Gorgious56!
    • bimtester: if lang argument is not set use feature file lang for output messages, improves #1910 Thanks Bernd Hahnebach!
    • bimtester: update log and smartview, they still are deactivated by default, fixes #1892 Thanks Bernd Hahnebach!
    • You can now add feed relationships in a Brick model from IFC elements
    • From an IFC element, you can now add a new Brick element in a Brick model
    • Assigning a brick reference now adds a 2-way IFC reference in the Brick model
    • Little utility to help printing out maintainable classes and other classes in contractual documentation.
    • bimtester: improved language support #1928 Thanks Bernd Hahnebach!
    • bimstester: feature cleanup and more german support Thanks Bernd Hahnebach!
    • get_total_inverses now efficiently gets the full number of references to an entity to optimise editing. See #1904.
    • bimtester: gui, initialize ifc file and feature file text Thanks Bernd Hahnebach!
    • Allow to assign IfcRelSpaceBoundary to an object (#1902) Thanks Cyril Waechter!
    • Allow to manually update boundary connection geometry (#1899) Thanks Cyril Waechter!
    • bimtester: fix gui, works with feature file now instead of feature directory Thanks Bernd Hahnebach!
    • Converting brickschema projects to IFC libraries now works on IFC2X3
    • Assigning library references now works on IFC2X3.
    • Editing object placements is now 3x faster on large files. See #1807.
    • #1785 HdfSerializer read-only option Thanks aothms!
    • Added information for debugging level parameter Thanks Felipe Mesquita!
    • #1895 don't signal element ready when result is empty Thanks Thomas Krijnen!
    • Fix #1889. Allow explicitly overriding data types when editing psets.
    • #1153 draw.py timing Thanks Thomas Krijnen!
    • #1153 update draw.py with two new options Thanks Thomas Krijnen!
    • #1153 option to preprocess shape into sets of profile edges Thanks Thomas Krijnen!
    • #1885 consider schema type when copying attribute values Thanks Thomas Krijnen!
    • bimtester: Fix numerous language issues with french, italian, and dutch Thanks Bernd Hahnebach!
    • (slightly) Optimise batch removing objects Thanks Gorgious!
    • More slow progress in getting annotations round-tripping. See #1153.
    • You can now associate IFC elements with Brick elements and navigate to them
    • You can now assign and unassign library references
    • New UI to add / edit / remove library information and references.
    • Raise default section height from storey from 1.0 to 1.2 Thanks Bruno Postle!
    • A whole bunch of new usecases for managing IFC library information and references
    • New utility to get layers of an element. See #1869.
    • Rebuild text annotations to have leaders in the same object and use text literals. See #1153.
    • Viewport annotation decorations now scale based on paper size. See #1153.
    • Drawing annotations now are stored in IFC using ObjectType conventions. See #1153.
    • Reimplement roundtrip of most annotation elements for drawings. See #1153.
    • New experimental OBJ2IFC script
    • tree.protrusion_distances() Thanks Thomas Krijnen!
    • Purge old 2D element drawing system, so we don't get double the symbols on drawings.
    • Swapping a Blender material for another is now auto synchronised.
    • Optimise object placement change checking, so medium sized project exports are 5 seconds faster at minimum, but can be much higher since false positives are culled.
    • Load CJIO on execution instead of initialisation Thanks Laurens Oostwegel!
    • show property description in pset_template ui Thanks Vukas Pajic!
    • Geometry caching is now enabled for model importing
    • Changes are now synchronised prior to switching representations.
    • [BlenderBIM] Tools to load IfcRelSpaceBoundary (#1864) Thanks Cyril Waechter!
    • Scale changes are now auto synchronised on export.
    • Improve support for Powerproject 14.0 import (#1865) Thanks ecke101!
    • Integrate ifccityjson in BlenderBIM (#1859) Thanks Laurens Oostwegel!
    • Implement cache updating for drawings. See #1153.
    • Resolve #1836. Scaling in Blender is now auto resolved when representations are updated.
    • Purge old dumb door and dumb window tool to prevent confusing users
    • Add annotation symbols for doors, windows, and bunny to the demo library
    • New IfcOpenShell utility to get instances of an element type easily
    • #1785 omplete stored_settings / requested_settings check Thanks Thomas Krijnen!
    • Consistent setting type Thanks Thomas Krijnen!
    • Resolve #1860. Brickschema is now optional.
    • Drawing module now is in sync with latest C++ upgrades. See #1153.
    • Allow tree.select(BRepElement) Thanks Thomas Krijnen!
    • #1785 check settings in cache and upgrade to world coords Thanks Thomas Krijnen!
    • Fix casts in XML serializer Thanks Thomas Krijnen!
    • ifccityjson: it is now easier to extract one LOD Thanks Laurens Oostwegel!
    • ifccityjson: prevent interior holes in faces as there is a bug in the geometry generation Thanks Laurens Oostwegel!
    • New feature to select all objects in same container
    • New feature to select the container of an object
    • Resolve #1750. You can now save IFCs under a relative path to your Blend file.
    • only call expensive wstring_convert() when necessary Thanks Thomas Krijnen!
    • #1785 geometry caching caching Thanks Thomas Krijnen!
    • Resolve #1749. You can now save as another IFC filename.
    • Rename some files with more sensical names Thanks Thomas Krijnen!
    • #1153 #1852 project points to form SVG HLR cut plane Thanks Thomas Krijnen!
    • #1153 evenodd SVG styling. Thanks Thomas Krijnen!
    • IfcConvert : SEW_SHELLS on svg serializer Thanks Thomas Krijnen!
    • #1153 boolean subtraction on parts Thanks Thomas Krijnen!
    • --cache and subtraction in draw.py Thanks Thomas Krijnen!
    • Add schema caching to Brick schema loading.
    • Implement new Brickschema project browser.
    • Slightly more robust deletion tracking.
    • ifccityjson: Fix bug dependency updated CJIO where cityjson vertices got transformed automatically Thanks Laurens Oostwegel!
    • #1153 another small hack to get boolean projection working more generally Thanks Thomas Krijnen!
    • #1850 Process extrusions of comp profiles seperately Thanks Thomas Krijnen!
    • #1743 don't consider bbox in opening subtractions Thanks Thomas Krijnen!
    • #1785 geometry caching on multi threaded iterator Thanks Thomas Krijnen!
    • #1153 svg subtraction settings Thanks Thomas Krijnen!
    • #1785 quick identity check to keep trsf form at identity Thanks Thomas Krijnen!
    • Add tutorial to ifccityjson Thanks Laurens Oostwegel!
    New fixes:
    • Fix bug where drawing objects could be added to the wrong context.
    • Fix bug where editing then switching to the current representation crashes.
    • Fix bug where syncing an object removed from the collection tree breaks.
    • Fix #2002. Fix bug where sometimes shape IDs wouldn't be pure integers.
    • Fix #2001. Fix bug where you could not undo deletions.
    • Fix #1998. Fix bug where colours don't show if styling is applied to the mapped item instead of the actual representation item.
    • Fix error when updating representation on object data with no BIMMeshProperties Thanks Gorgious!
    • Fix bug where you couldn't select properties with a dot in the name for IfcCSV
    • Prevent error if last temporary section has been removed (#2000) Thanks Gorgious56!
    • Fix shader glitch when user deletes last cutaway object (#2000) Thanks Gorgious56!
    • Fix bug where zero durations were not allowed in task times.
    • Fix #1995. Bug where section cutaways didn't work in Blender 3.0.
    • Fix bug where you could not add properties to projects themselves.
    • Improve boolean reliability. #1948 clear tmp list Thanks Thomas Krijnen!
    • #1985 Fix bug with selecting objects via geometry tree. Consolidate and correct shell count checks in tree Thanks Thomas Krijnen!
    • Fix propagation of kernel settings (affects multi threading) Thanks Thomas Krijnen!
    • Fix #1934. Fix bug with improper nesting of subfolders when exporting IfcZip.
    • Fix #1954. Fix bug where importing MSProject XMLs with no project names failed.
    • Fix IfcCSV import bug.
    • Fix #1989. Fix bug where you couldn't export to IfcJSON, since it couldn't be imported again.
    • Fix bug where you could assign a product twice to a process.
    • Fix #1931. Fix bug where duplicated type products should not share material associations.
    • Fix bug where annotation decorations didn't show correctly in Blender 3.0
    • Fix #1925. Fix bug where nested collection deletions were not synchronised properly.
    • Fix bug in BCF. Correct HeaderFile (#1942) Thanks molitoris!
    • Boundary geom creation : fix math + small ui fix (#1938) Thanks Cyril Waechter!
    • Fix bug where IfcPatch IFC4 migration could break on Revit files
    • Improve boolean reliability significantly. Thanks Thomas Krijnen!
    • Fix booleaning bug. #1914 only proceed with 'face addition check' when first operand contains open shells Thanks Thomas Krijnen!
    • Fix #1692 memory leak in get_info_2() Thanks Thomas Krijnen!
    • Fix #1917. Fix warning where the relating type classes data couldn't be accessed.
    • See #1917. Refactor and fix warning message when you haven't got any contexts in a project yet.
    • Fix #1923. Fix bug where creating a new structural analysis model broke.
    • Fix #1913. Fix bug where filtering by decomposition didn't work on IFC2X3.
    • Fix #1921. Document issue with installing on outdated Ubuntu distributions.
    • Prevent error if id has no geom representation in IFC debugger (#1924) Thanks Gorgious56!
    • Fix bug where libraries didn't work in IFC2X3
    • Fix #1816. Fix bug where cameras weren't allowed to be optional in BCF 2.1.
    • Fix bug with missing system arrows in visualising offset models and sink/source mixed flows.
    • bimtester: do not break bimtester if translation files are missing, fixes #1910 Thanks Bernd Hahnebach!
    • Fix bug where Blender name wouldn't match IFC Name when reassigning class. See #1902.
    • Fix segfault thanks to aothms.
    • Fix percentage loading implementation with the new more accurate progress number.
    • Prevent crash on export for obj with no material (#1903) Thanks Cyril Waechter!
    • Fix bug where selecting type occurrences did not work
    • Fix bug where updating owner history may not work if you were using it outside Blender.
    • Fix model segfault. #1897 handle nesting in get_decomposing_entity_impl() Thanks Thomas Krijnen!
    • Fix bug in FM utility for grabbing classes from the draft FMHEM standard
    • Fix bug in convert length unit recipe where IFC2X3 ownership history fails.
    • Fix #1886. Fix getting layers for IFC2X3 files.
    • Fix bug where subelement coordinates were incorrectly calculated in non SI units
    • Fix bug where you couldn't copy quantities to other elements
    • Fix bug where unlinking a style that was invalidly linked didn't work.
    • Fix minor error in console when changing drawings. See #1153.
    • Fix bug where annotative grids did not sync.
    • Fix #1857. Fix bug where deleting from the outliner was not tracked.
    • Fix #1872. Bug where duplicating an object didn't duplicate its styles.
    • Fix bug where style colours were not auto synchronised.
    • Fix bug #1854. Materials are now auto replaced in Blender when you assign a new IFC material.
    • Fix bug where an added default material was not linked and auto synced.
    • Fix bug in IFC2X3 where updating style colours didn't work.
    • Fix bug where diffuse colour was not correctly extracted from nodes
    • Fix #1856. Bug where you lost your existing container or aggregation when you added a new aggregation assembly.
    • Fix #1764. Bug where OpenLCA UI would freeze if it couldn't connect to OpenLCA.
    • Fix #1855. Bug where authoring type dropdowns didn't refresh.
    • Fix bug where removing a representation from a typed instance didn't remove all data users.
    • Fix representation where removing a representation left objects with an empty mesh. Now a proper empty is used.
    • Fix bug where non-geometric objects caused the representations UI to not display
    • Fix bug where assigning a type did not use existing representation data in the scene if the context had changed
    • Fix bug where adding a representation to a type instance didn't share meshes
    • Fix bug where you couldn't add a plan representation to something with no context identifier
    • Fix interface bug where representations assigned directly to a context aren't shown
    • Fix bug where existing meshes were not deleted when switching representations.
    • Fix bug where adding a representation to type instances didn't ensure it was added to a geometric type
    • Fix bug where pie update container didn't work.
    • Fix bug where copying an instance did not auto link the meshes.
    GorgiousbitacovirbrunopostlevpajickrandeCyrilbasweinJesusbillLarsDarth_Blenderand 1 other.
  • edited January 2022
    0 ( '')( '') Great work!
    0 ( '')( '') Fantastic!
    0 ( '')( '') Superb!
    carlopav
  • Hello,
    I installed Blender version 3.1.0 and it doesn't work with BlenderBIM Add-on v0.0.220130. I didn't have a previous version installed.
    Is it necessary to use different versions?
  • edited March 2022
    I just downloaded blenderbim-220309 developer build from:
    https://github.com/IfcOpenShell/IfcOpenShell/releases
    I tried to install the blenderbim-220309-py39-win.zip on Blender 3.0.1.
    I get the following error.
    No module named 'blenderbim.core.document'
    paulcaicedo
  • @paulcaicedo said:
    Hello,
    https://github.com/IfcOpenShell/IfcOpenShell/issues/2083
    paulcaicedo
  • edited March 2022
    Thanks @theoryshaw
    I installed version 3.0.1 and it works all ok. I am not sure how to change the python versions and where for version 3.1.0. This is good for now.
  • https://github.com/IfcOpenShell/IfcOpenShell/releases
    The blenderbim-220316-py39-win.zip is not working on Windows with Blender 3.1.0
  • edited March 2022
    I think you have to use the "-py310-.zip" file
    Coen
