I need to create bcfs from excel data. Has some one seen somrthing in this regard? If there is nothing I may give it a try with IfcOpenShell and Python bcf parser as well as pndas to read the excel.
To my understanding a BCF file is a xml file which describes the camera perspective points and a tag/name whatever to describe the issue?
I am confused what kind of data the Excel file contains.
I have never heard about bcf parser.
Still quite confused on what specifically trying to achieve, but taking a wild guess I would say you need the following modules: xlsxwriter
or pandas lxml
xlsxwriteror
pandaslxmlifcopenshell does contain a python bcf parser.
The excel file will contain the issue data. Each issue will be one line. Each column will be one issue attribute like title, created by, comment, etc
I am aware about the need of pandas to get the data out of the excel data sheet.
@Coen some links about bcf parser of IfcOpenShell https://community.osarch.org/discussion/453/ and https://community.osarch.org/discussion/634/ great stuff :-)
