BlenderBIM: How do I start ?
Hello
I just installed Blender Bim and tried to follow some videos i found, but i dont have all the elements available.
I did created a project and assigned a the mesh as a IFC wall, created a view but cannot do more than that.
Is there a simple tutorial ? Do i need an IFC template and if so, where can i get it?
Thanks !
https://wiki.osarch.org/index.php?title=Category:BlenderBIM_Add-on
Thanks for replying! I managed to understand some of the basic concepts and created a few wall segments from the template.
However i would like to understand how can i transform any custom geometry into BIM elements something like in this short tutorial
Is this still possible?
If i apply an existing wall style to a custom geometry with modifiers (like in the video) will it react with the window, doors openings interact with other BlenderBim functions and tools?
I understand that i need to assign a custom 2d symbol for any custom doors and windows. Where can i find more information about this?
Thanks again !
https://learn.osarch.org/
Hardest part for me was trying to learn Blender, it's also really helpful to familiarize yourself with the IFC schema.
Short answer: No. But I think @theoryshaw does a lot experiments with roundtripping. He experiments how we can store certain functionality within an IFC schema.
Yes Indeed, it's not easy to find the information you want or how to do it. What @Coen said about getting familiar with the IFC Schema is i.m.h.o the most important thing. Because everyone learns different and would like things ordered and sorted in a different way is difficult to find the information, but it's there. A long but very useful video Series on IFC is this one: Open BIM and IFC , thank you @Moult.
I`v been using Archicad and Revit before but in BlenderBim is less automated so there are things that i was not aware of probably
The Ifc Class is the top hierarchical category and followed by Type?
Lets say I have a dumb mesh in Blender. Do i need to assign it to a Class and the class needs to be of a Type?
Why is this not possible anymore?I thought that was really a great workflow! I know that working with walls by extending and intersecting segments is handy but I also want to be able to design my floorplan using Blender tools , including Geometry Nodes and modifiers and then somehow assign them to BIM elements
In fact i really think and hope Blender BIM will be compatible and included in Geometry Nodes. Parametric modelling is really the key!
Was it ever possible? I'm not aware
Yes, that would be great. But I think BlenderBIM is for now an IFC authoring tool, not (yet) an IFC creation tool. Maybe these threads will shine some light on the expectations of BlenderBIM:
https://community.osarch.org/discussion/800/
https://community.osarch.org/discussion/793/
I wholeheartedly agree with you, I think it's slowly getting there? Technically if you know the python API, Blender is already one big parametrics mesh modelling software. :-P
I'm not a lingust, but as far as I can tell the term "authoring tool" refers to a tool designed to produce content. So that means that "IFC authoring tool" and "IFC creation tool" are synonyms.
Check this out: https://blenderbim.org/blenderbim-vs-revit.html
Is revit IFC authoring tool? Most people would probably say so. You can see from the chart that BlenderBIM add-on is actually rather capable. The main problem of BlenderBIM add-on is, that it is currently under heavy development, which somewhat automatically means it's not so extremely user friendly as Archicad or Revit.
I don't exactly agree with @Coen here. BlenderBIM add-on aims to take advantage of all the capabilities of Blender. You can take any finished model and turn it into a BIM model. You just need to know how and that's the hard part.
@JanF
This is true, but as I understand the OP wants to know how to store parametric capability with an IFC file? Like you made a gif once showing how to use the walltype functionality of BlenderBIM.
I thought OP means specific these kind of things? I don't want to post things here which are simply not true.... But expectation management can't also be underestimated in my opinion to prevent user dissapointment.
I think so. Please take a look at the video i first mentioned in the initial post. An older tutorial by Dion Moult
The first part where he is modelling a floorplan layout, using just Blender tools including modifiers, and then adding doors, creating drawings, etc.
And I thought he was just basically generally asking how to work with BlenderBIM add-on, coming from Revit or Archicad.
@Constantinesis could you please be more specific about what you are trying to do?
You can take any object and assign it any class, like this:
@Constantinesis
That's already quite an old video like you say, I think the latest Blender version doesn't have dumb wall option anymore.
I think you can now use a demo libray, this way after you export the IFC, it can be imported and adjusted/edited again in Blender. You're still able to edite the wall thickness of a wall type just like in Revit.
If you use modifiers like array/boolean you can model really fast. However when you export it to IFC and import it Blender again, you lose all your Blender modifier functionality. I thought you meant that....?
For exampe in this thread a complex geometry stair can be modeled very fast using different modifiers. However when exporting to IFC you can't edit the stair anymore like you would with type parameters as in Revit.
I could live with that for now, If it keeps the class association even after modelling it is great.
Thats what i love in Blender is the speed and flexibility which you can model things like that. Actually spiral stairs are very fast and easy to model using combination of Array, Screw, Solidfy, Boolean tools if you need so.
The most common modifier i use is the Solidify. This gives parametric thickness and you only need to model 2D meshes and lines.
I am not even mentioning the Geometry Nodes which you can also use. But will it be represented in section cuts?
Actually i am confused because i saw there is a real time section cut shader and viewer but in the same time you also have the SVG export. I prefer the real-time section view of the model. Can that be used for horizontal sections (floorplans)?
I have also just discovered Measure It Arch, another free plugin, really amazing for associative dimensioning, annotations but also line style representations. I saw there is an interest for Blender Bim and Measure IT arch to work together
My most important question is, if i assign a class to a custom mesh, will it be correctly represented in floorplan and section drawings? WIll i be able to add windows and doors or do i need to change their voids as to cut through all the thicknes? What does Type mean in this context? Is it a higher category than of the Class?
I mean do i need to also assign a Type to the custom mesh, together with a class?
@Constantinesis
Those are all good questions. I never tried to make a drawing with Blender, so unfortunely I can't help you too much.
1) If you take a simple cube and assign an IfcElementType > IfcWallType
2) Then you can click the green cube and you Cube (you mesh name) appear under Authoring
3) If you click 'Add Type Instance' you see the mesh being moved to the IfcProject in the Outliner
4) Now you can keep adding instances of that type, and move them all over the place in Blender
5) You now only have to edit one mesh, the other instances will be edited as well.
6) When exporting to IFC you see if worked.
7) If you imported the IFC in Blender again you still have this functionality. Only the mesh got triangulated with import and exporting but you can fix that using dissolve faces.
EDIT: it seems the images are being compressed and blurry by this forum, someone (sorry forgot your name) on this forum explained this to me. But I coud not find any non-forum documentation about this very useful feature.
What about the Layer thicknes associated with the type? WIl it the instances change if i update its layer thickness ?
I also saw in a video that you need to assign a material to the type and thats where you set the thickness.
But i think that the thickness can only refer to a bounding box of the object. Will not apply correctly if you have a polygonal prism as a wall for example
I thought we were talking about type parameters :-)
I don't know about layer thickness parametrics capability/functionality within BlenderBIM . But I linked the documentation to Building Smart. Maybe it's useful.
Is the dimensioning done with BlenderBim? How do i use the dimension tools? I wasnt able to make them work.
Did you go through the wiki?
https://wiki.osarch.org/index.php?title=BlenderBIM_Add-on_exporting_2D_documentation
Thanks, just tested and its indeed sectioning through any mesh which is assigned to a IFC class!
Is there a way i can have a 2d camera view interactively showing the section cuts? It would also be nice to see the generated drawing inside Blender
I can see the Temporary section cutaways but its without any CAD symbol styles.
I`v seen in the wiki docs that the 2D drawing styles are set on the separate IFC file but where exactly i can find them?
"As mentioned earlier, the resulting SVG file gets its final appearance from the style sheet, defined in the Project data directory. The CSS conrols the appearance using classes, which means that by assigning an arbitrary class, any group of objects can be assigned a specific appearance. Some of the classes are defined as an example in the PROJECT_DATA_DIRECTORY⁄styles⁄default.CSS, defining the appearance of the annotation elements added through UI (see below) and some basic material hatches. The symbols and hatches referenced by the CSS file are standard SVG files stored in PROJECT_DATA_DIRECTORY⁄templates⁄"
I couldnt find these styles. Where iss the Project Data Directory?
Can i edit and add new entries into the CSS file?
If i want to create a custom door i can assign an existing type and then it will get that floorplan symbol but if i want a custom dimension or symbol how can i create it?
https://wiki.osarch.org/index.php?title=BlenderBIM_Add-on_Setting_up_a_BIM_Project
The path in the link is no longer correct though, it seems to be under blenderbim\bim\data\styles now. Yes, you can edit the css and svg files and change the appearance in any way you like, that's the idea.
Why the directories are no longer exposed in the UI I don't know. @Moult ?
If you understand svg you can just add the code for your symbol into the right svg file. I don't think there is a way to draw it graphically and save as svg in inkscape or illustrator, so that blenderbim will understand it.
Wondering, what is the way to add doors and windows? And can they remain associative such that if a wall is moved the doors and windows follow? I've looked through most of the info in the wiki and elsewhere, but still find lack of info about doors and windows.
Another question - how does one define spaces? Are they manual at the moment?
I too am having a hard time getting started - I'm both new to BIM and especially new to Blender, and it's a lot to learn. I'm working my way through some of the Blender tutorials and hopefully I'll get there.
One thing that I think would really help me and I'd bet a lot of others was if there was a demo video that went very slow and deliberate, like the Blender donut tutorial, that created a basic model - maybe something with a slab, some exterior walls and a roof, a door and a window, two stories, and maybe a stairway and an interior wall. Just seeing someone create this would be helpful but especially if they were going slow and narrated which tool they were using or what hot-keys they were pressing as they were adding elements, along with whatever modifiers and snaps they had turned on, and if the selection is to the face or vertex, etc. Moult's demos are awesome but he can move so fast I just can't keep up! It'd also be great to see how things lined up - are the walls and roof aligned to the centerline of those meshes or the exterior?
The Demo library included in the current BlenderBIM releases is very helpful in that it's got some basic IFC classes defined, though I don't think it has roof or stairs, but I think I could figure that out if I had to (at least roof, I don't know what to do about stairs, because there must be a void attached to them/the ceiling somehow and I don't know how to make a mesh that looks like stairs)
How about we host a unilateral screenshare May 5th, at 20:00 utc.
We can all ask questions, i can show peeps what i know, and I can hand off the screen for others to show what they know. Keep it conversational.
https://meet.jit.si/openbim
@theoryshaw any chance the meeting can work if it's a little earlier in the day?
Sure, how about 17:00 utc?
I apologise for being so late to this discussion, but I wanted to take a step back on how development has evolved, a sort of "there and back again", if that makes sense.
The BlenderBIM Add-on started as a way to export Blender data into IFC. You'd model whatever you wanted using the rules of Blender (modifiers, sculpting, whatever, and nowadays, geometry nodes), and press the export button, and voila, you'd get an IFC.
Although this gives you unlimited freedom to use the full capabilities of Blender, there are many problems with this approach. Ignoring speed, scalability, and code maintenance, the issue is that BIM is not just about you in Blender, it's about modeling in a way that is compatible with all disciplines, not just geometric.
Let's say you modeled a wall using a solidify modifier, thus having a single edge running along the base of the wall as it turned corners around a room. Imagine that wall is arrayed up each floor of a multistorey building. How would a quantity surveyor deal with this? If you didn't have a custom quantification script to provide the net side area, how would a surveyor calculate that in a standardised way? What if only one of those wall portions were structural? How would a structural engineer associate their analytical model with just a portion of that wall? Does the axis of your wall align with the structural axis required for analysis? What about building energy modeling? Is your wall adjacent to the same energy zone types throughout the entirety of its extrusion? What about construction sequencing, how is that wall divided per floor for time data? What about life cycle analysis? Is the Blender material definition of that wall really sufficient to connect to a life cycle graph in a standardised manner? What if a drawing needed to be generated? Is the mesh efficient for boolean operations? What about multi-user editing? Facility management? Linking sensors? MEP systems? (I know, it's a wall, so probably not too related, but you get the idea)
This is not a simple problem and often underestimated in our industry. Building a "draw wall" tool is relatively simple. Ensuring it follows certain rules designed to be compatible with all disciplines is much harder.
To solve this, the BlenderBIM Add-on was designed to work natively in IFC. Blender was no longer a modeling tool, it was simply an interface through which you could perform authoring actions that were allowed by the IFC schema. This meant that the add-on could now handle a lot of disciplines to a great level of detail that was never seen before in the industry. However, it also meant that all the freedom of "I can use all of Blender's features" were lost. Even the basics, like the ability to press "Undo" in Blender had to be redesigned. To create a wall, we first needed to build everything else under the hood.
Slowly, IFC's modeling capabilities have been reintroduced one by one into the Blender interface, so slowly we are being able to address the so-called basic modeling tools again. IFC offers a few modeling capabilities that cover the vast majority of modeling tasks, like:
Notice there are things which don't exist in IFC (yet) like arrays, and mirroring (well, kinda, yes, but not the way you think), and group instances. So it's certainly not a perfect system.
So instead of taking the approach of "what are all the Blender features I can use", perhaps start with "is there a preferred BIM modeling technique that allows data to be structured across all disciplines?".
If you choose not to use the IFC modeling tools, you have two choices. Either model something manually as you have, but then its your responsibility to make it play nice with all the other disciplines. Alternatively, model something using modifiers / nodes / scripts / whatever, but then in addition to adding all the data yourself, the parametric behaviour will only ever exist in your Blend file. Once you lose your Blend file, that parametric goodness is lost.
I hope that sheds a little insight.
@Moult Thanks alot for this insight into the BlenderBim story. Glad to hear that you are slowly bringing back the modelling and designing capabilities!> @Moult said:
I think that having multiple choices is the right approach because the design process is structured into multiplle parts. The first part is always the concept design which i think Blender can really have a strong point. Then you have the other stages where things go much closer to construction documentation specialities. Of course there i always a back and forth between and the process is not linear.
I am already suprised that you can already assign an IFC class to any mesh very easy and then can create floorplans and sections
Now how you keep the parametric BIM capabilities during this dynamic process its the real issue and challenge i suppose and all the other BIM softwares have their own methods some better than others.
In my view however i think taking advantage of all Blender strengths and features is crucial and Blender Bim cannot just be an authoring tool if it wants to be largely adopted.
I am using Blender for a couple of months and i think si so powerfull that you can almost find a way to solve most of these issues, especially through its object data system and constraints, not to metion scripting.
The real challenge is automating this process and i`v seen this has been discussed already.
Going back to the tutorial and learning aspect I really want to suggest something else which i am suprised it did not happen yet : creating a community Discord channel. I am also new to Discord but my learning process would have never been the same if i wasnt there for example in the Blender Community channel.
Another aspect is that i wish that YouTube would be the main video sharing platform for these tutorials or tips. I find it difficult to find the videos that have been already uploaded here and hosted on other servers.
I dont want to undermine the value of OSarch Community website but i believe a live chatting presence in Discord for BlenderBim and Blender users is essential as its popularity is really huge. By the way, Blender CAD Sketcher is already there and its been super usefull.
I`v been asking the same thing and i havent really tested yet with BlenderBim but using Blender native constraints you can achieve something like that using parenting and other constrants. For example one feature that i like in Archicad is when you add a window or a door it will be constraint to the wall surface and can only move on the plane of the wall. I tested something like that really fast in Blender and had an object be constraint to a curve from which you extrude a wall. If the window or the void is child of the curve or the extrusion and is also constraint to the curve with Track To or something similar, then it will perform exactly like that.
The biggest challenge is however to automate some of these processes because it can become reallly tedious.
Working on a library of these kind of objects and having them as Assets is also one way. But these should be recognized by BlenderBim too.
So the Asset feature of Blender should work nicely with BlenderBim. Is this possible already?
It is definitely planned to allow arbitrary parametric (modifiers / nodes / scripts / whatever) behaviour in the future. I completely understand where you're coming from - I have a background in Blender modeling, so I certainly know which tools I'm missing :) Arrays are definitely on the top of the list. However, this is not something we are doing alone, so it takes a bit of time to settle on a system that works.For example, we'd very much like not just Blender intelligence to be supported, but FreeCAD too, or OpenSCAD, or IFC.JS, etc. So yes, it's on the roadmap, but it's not something to rush into. The current proposed strategy is to record an optional "parametric engine" behind an object, so that an authoring app that can recognise the identifier of an engine can connect to the parametric system used to generate the object (both geometry and data). This way someone can build a "parametric engine" that say supports the Blender modifier stack (or a subset of it), and knows how to accommodate things like quantity take-off, or realignment of structural coordinate systems, or generation of accompanying 2D symbols, etc.
I'd recommend https://osarch.org/chat - it supports both Matrix and IRC, both of which are mature open source live chatting technologies. There are typically 30-40 people online. I highly recommend joining :) As for YouTube / Peertube, we can certainly do a lot better. Do you have time to help?
To an extent. You can create a wall using whatever (e.g. arbitrary mesh) and you can insert a window / door using the BlenderBIM functions and it'll "just work" assuming the wall is along the local X axis, as that is the rule in IFC. In the future, with more developers, we can make these assumptions less restrictive. And of course, as mentioned before you'll lose the parametric data until we build support for parametric engines, but at least the tools will work. Here's an example:
In Blender, an object can only have one geometric data (e.g. mesh / curve). In IFC, there are usually many. Each geometry belongs to a "context" determining the purpose of that geometry (e.g. 3D shape, 2D symbol, analytical curve, etc). You can check the contexts available in Scene Properties > IFC Geometry > IFC Geometric Representation Contexts. On a fresh project, we create the most useful ones out of the box for you by default. Then, each you can add a new geometry to an object for a context by going to Object Properties > IFC Geometry > IFC Representations. You can switch between representations there too. The doors and windows that come with the demo library give a good example of this.
The real time section cut is a shader trick that is fast, but not a true boolean. It is good enough for a live preview, but not good enough for professional construction documentation. The SVG-based drawing system is a true construction documentation system, including foreground, background, semantic metadata, sheets and drawing references, object based annotation, and more. That said, it makes sense to at least trigger the temporary section cut when previewing a drawing, so I'll add that to the roadmap.
The BlenderBIM Add-on already has integration with the MeasureIt Arch Add-on. However, MeasureIt Arch is not an IFC native system, so drawings only ever exist in Blender. Drawings are also a bit more than just dimensions, which include element filtering, metadata-based styles, and drawing references, so the integration is pretty limited. Last I checked MeasureIt was focusing on dimensions, which is great, but doesn't satisfy our needs. The SVG-based drawing system in the BlenderBIM Add-on is native IFC, so drawings exist in IFC and can be interoperable in other apps like FreeCAD, IFC.JS, etc. It also means you can generate drawings from non Blender-produced IFCs, or headlessly on a server for larger projects with hundreds of drawings. Object associative dimensioning is supported, but geometry associative dimension is not yet supported. Line styles and text styles is supported but needs a lot of work. You can read more here: https://github.com/IfcOpenShell/IfcOpenShell/issues/1153
Manifold geometry will be, yes.
You don't need a type, but it is highly recommended. In construction, most objects belong to a construction type. Like wall types, door types, furniture catalogue types, duct size types, and so on. When a project moves past early geometric exploration, you can create construction type objects. This is like an asset library that you can insert. So when you create a wall type, all walls of that type will share its thickness and material properties. Updating the thickness will propagate to all occurrences of that type if the wall type is defined with a parametric thickness.
When the temporary section cutaway feature integrates with the viewport drawing annotations in the future, this'll probably be want you're after. Not yet though.
It is now available in the add-on settings to prevent accidental changing in the project properties and prevent confusion with IFC project properties vs local data directories.
You can use Inkscape to draw these (in fact, I used LibreCAD DXFs converted into SVGs in Inkscape to create them - imagine drawing a concrete hatch just using code, impossible!). Then, you can copy and paste the SVG code into the supplied SVG template files. markers.svg includes marker designs like arrowheads for dimensioning. patterns.svg includes hatching patterns. symbols.svg includes standalone symbols like annotation tag bubbles, rectangle material tags, hexagonal window tags, etc. Then there are templates for titleblocks and so on. When you create these, just keep a very close eye out for the dimensions used as real world millimeters are used for everything, including pen thicknesses.
Doors and windows work like any other asset. Activate the BIM tool (green cube in viewport), choose your door or window type, and click on a wall. Then with the wall selected, position the 3D cursor (shift RMB) where you want the door to be and add the door / window (Shift-A).
Yes :( Draw them manually, then treat like any other spatial element (building, storey, etc).
I won't be able to join but this is an excellent initiative and I hope my writeup helps for the moment.
@theoryshaw that time works for me!
@Moult - You are completely correct that array tools and others make it hard to schedule properties correctly. This is also an issue that I've had to work around in Freecad with formula-based calculations of array properties. It depens though, on the intended use of the model.
However I am still left with questions:
Is BlenderBIM a really fast IFC viewer/analyzer/clash detection tool/FM tool/etc and/or also a design tool? If it is also a design tool, then what is the best way to use it? I know there are tons of ways to use BlenderBIM, but showing a few examples (i know that there are some, although already dated?) and a small description of use cases would go a long way for further adoption.
I am always exploring the best way to do basic BIM architecture - easy way to place and manipulate walls; associative floor levels, doors, windows, and spaces; auto or semi-auto floor slabs and ceilings; scheduling; and documentation. Beyond the basics further advanced features that are super useful to have are an easy collaboration workflow between multiple users and platforms, parametric objects like stairs and curtain walls, and an easy way to work with components like furniture and plumbing (LODs, embedded plan and elevation representations), and documentation automation tools. I usually work on the other side of the architectural spectrum, dealing with quite complex and large massings, but the basics above are what most architects (including myself) spend most of the time with. Do you and the community think this type of functionality would fall well within the spectrum of what BlenderBIM has to offer? Or maybe it already offers a lot of that and I've failed to understand well. I did watch the session on youtube where the wall tools already seem to offer most important features.
I would like to suggest showing a few ways to use BlenderBIM over. maybe good to place on blenderbim.org. For example there can be sections to show each of the following with an overview of best uses:
BlenderBIM for architects & designers
General info
Design geometry with native IFC via BlenderBIM with wall tools and dynamic opening tools.
Convert Blender geometry into IFC
Small scale
Medium and Large scale
Renovations
BlenderBIM for engineers
General info
Profile based elements and clash detection?
*Steel profiles
* HVAC ducts
*pipes?
*framing?
*rebar?
BlenderBIM for project managers
*3D coordination
*comments?
*clash detection
*Quantity Takeoff
BlenderBIM for contractors
The one place where all building information can be collected and viewed
*Schedule of materials
*4d? timelines?
BlenderBIM for owners and FMs
* MEP controls
* Awaraness of all elements and sizes for maintenance, repairs, and renovations
BlenderBIM for consulants
* View all project data without expensive software
Anyone else?
