What I wish try is connect an Octave Variable to a node or python script, like this:
(OctaveFile.m)
a = 30
b = 35
c = a + b
d = 'value from python script or node'
(PythonScript.py or node)
d = c * 2
I wish use octave because is a lot more easy do operations without install dependencies, and if this integrated to nodes like pyflow, sverchok or dynamo for freecad, then we could advance a step to AI because Octave is related.
https://github.com/mlyundin/Machine-Learning
hm. there is some interesting stuff rewrited octave in python
we have ntework udp node, but it needs to be upgraded to handle any other types as tcp w/o lost packages.
If to update node tree with dependencies. Maybe there is other way. You can start issue on github sverchok page and maybe someone will handle.
long time
basically here https://t.me/sverchok3d
Many examples added:
svg truss joints
truss joints
freecad
open3d
origami
fields
archicad
gcode
puzzles
Dxf export example now inside "utils" templates for SNL node (scripted nodes section of nodes menu). And dependency ezdxf in properties to install with one button. Remember to run blender as administrator in windows to pip install external Python libreries
Hi @nikitron (I hope you are the person to ask) I decided as a Christmas treat to try Sverchok, it looks very interesting. Unfortunately, I had a problem installing...
I'm using Blender 4.0.2 with BBIM Addon v0.0231219 on a Win10 desktop
Any help will be most appreciated
Hello!
May I sugest using Blender 3.x with Sverchok until Nikitron answers. I didn't have any luck with Blender4.x and Sverchok either.
Hi! There are probably errors in system console you can check.
Same problem for me too.
Disable BlenderBIM and restart blender. Enable Sverchok and then enable BlenderBIM later, this's works for me.
I'm using Blender 4.0.2 with BBIM Addon v0.0231104 on a Win11 desktop
New nodes:
* Spyrrow Nester,
* Adjust Surfaces
* Straight Skeleton (Two nodes)
* Data Tree Viz
* DXF export and import nodes
* Boolean Internal
Node updates:
* Area Node
* Viewer Draw
* Viewer Index
* Sthetoscope
* Nurbs Bireail mk2
* Get Object Data
* Get Nurbs
* Get Beziers
* Bevel
Misc:
* The "quick start" hint system
* The Cricket theme for the blender is sewn in
* Examples search function
* The "Orbit Around Selection" function next to the examples menu
* Most of the Cricket's addons are taken out to be installed with a single button from the settings
* We spoke at the Basalt SPO conference
* We spoke at the NOPRIZ conference
* We started a video series on YouTube
* The Addon mega-city was updated in the spring
* An article on habré on Straight Skeleton
@nikitron
I was checking the link and I found than is more like a comparison between python and octave
https://forum.freecadweb.org/viewtopic.php?p=471831#p471831
... In the link was suggested use oct2py but not luck because look like need an update
(OctaveFile.m)
a = 30
b = 35
c = a + b
d = c * 2
Concrete piles and caps with Sverchok
long time
svg truss joints
truss joints
freecad
open3d
origami
fields
archicad
gcode
puzzles
Hello there, long time...
DXF exporter in form of scripted node light added today, please, test.
Here is SNL code
TG channel - watch discussions
Hello!
@chakkree Hi, I tried your suggestion but no luck for me. I wonder if future updates will make this easier :)
Blender 4.0 not supported yet for viewers, only bmesh viewer works.
https://github.com/nortikin/sverchok/pull/4983
https://github.com/nortikin/sverchok/blob/master/docs/tutorials/Celling_00/celling_01.rst Started topics' series on tree for plates production.
location - Moscow, Poklonnaya gora, Brothers Fonchenco str.
https://rutube.ru/video/699546ca3e4af644c0a8ab23a7683f3f/?r=wd New lesson
pass
ав
Results of the year 2025:
New nodes:
* Spyrrow Nester,
* Adjust Surfaces
* Data Tree Viz
* Boolean Internal
Node updates:
* Area Node
* Viewer Draw
* Viewer Index
* Sthetoscope
* Nurbs Bireail mk2
* Get Object Data
* Get Nurbs
* Get Beziers
* Bevel
Misc:
that nested packing new node in sverchok
IFC export without ifc opens hell library
ifc export without ifcopenshell. Only geometry with minimal parameters.
zcad reads dxf from sverchok. And supports 3D view.
cool cad, meanwhile
I say! ZCAD is writen in Pascal? Long time since I've seen this language
Yes, on Sunday, investigated free Pascal. It is object oriented language. Fast and quickly compiled.
I h ave played some with generating stair, with DXF faces in zcad and with ifc in openifcviewer.
