@Coen my two cents about it: i thing that that panel is the right place to put the module. :-)
Also, it should be a module like the others (pset, ifcclash, georeferencing, etc...)
There is also the "demo" module to know how to structure a module, so if you follow that guide, you should get it
@Massimo
Thanks for the feedback...
I think I made it a module like the others?
I placed a folder here locally called spreadsheet_writer which contains the code
To see the demo module in action, you’ll need to enable it. In src/blenderbim/blenderbim/bim/init.py, uncomment the line for the demo module. When you restart Blender, you will see a new demo panel in your scene properties interface tab. Have fun!
I went into the demo folder, but see nothing commented, which line in which file should I uncomment?
I see this in the __init__.py of the demo folder
# BlenderBIM Add-on - OpenBIM Blender Add-on
# Copyright (C) 2022 Dion Moult <[email protected]>
# This file is part of BlenderBIM Add-on.
# BlenderBIM Add-on is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# BlenderBIM Add-on is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with BlenderBIM Add-on. If not, see <http://www.gnu.org/licenses/>.
# Hey there! Welcome to the BlenderBIM Add-on code. Please feel free to reach
# out if you have any questions or need further guidance. Happy hacking!
# Every module has a __init__.py file to load all of its classes. Every
# operation, property, and interface needs to be registered with the Blender
# system when the add-on loads. This is where it happens.
import bpy
from . import ui, prop, operator
# You'll need to provide a list of every one of your classes here. If you forget
# to specify your class, it won't load and you won't be able to use that
# operator, property, or interface.
classes = (
operator.DemonstrateHelloWorld,
operator.DemonstrateRenameProject,
prop.BIMDemoProperties,
ui.BIM_PT_demo,
# When the add-on loads, this register function is called. This allows you to
# perform additional tasks during startup. If you need to store custom
# properties, this is where you tell Blender where they are going to be stored.
# You might see more advanced registrations happening in other modules.
def register():
# Properties are usually stored on bpy.types.Scene when they are something
# that affects everything in the project, or bpy.types.Object when they
# affect a single BIM element.
bpy.types.Scene.BIMDemoProperties = bpy.props.PointerProperty(type=prop.BIMDemoProperties)
# When someone disables the add-on, we need to unload everything we loaded. This
# does the reverse of the register function.
def unregister():
del bpy.types.Scene.BIMDemoProperties
@Coen It's refering to these lines of code
you'll need to add "spreadsheet_writer": None in this dictionary so that it's automatically imported and registered afterwards. You'll also need to add your panel class in the classes list instead of classes = ( operator.DemonstrateHelloWorld, operator.DemonstrateRenameProject, prop.BIMDemoProperties, ui.BIM_PT_demo, )
@Gorgious
Thanks, that was not clear to me.
Like this?
# Copyright (C) 2020, 2021 Dion Moult <[email protected]>
import bpy
import importlib
from . import handler, ui, prop, operator, helper
modules = {
"project": None,
"search": None,
"bcf": None,
"root": None,
"unit": None,
"model": None,
"cad": None,
"georeference": None,
"context": None,
"drawing": None,
"misc": None,
"attribute": None,
"type": None,
"spatial": None,
"void": None,
"aggregate": None,
"geometry": None,
"cobie": None,
"resource": None,
"cost": None,
"sequence": None,
"group": None,
"system": None,
"brick": None,
"structural": None,
"boundary": None,
"profile": None,
"material": None,
"style": None,
"layer": None,
"owner": None,
"pset": None,
"qto": None,
"classification": None,
"library": None,
"constraint": None,
"document": None,
"pset_template": None,
"clash": None,
"lca": None,
"csv": None,
"tester": None,
"bimtester": None,
"diff": None,
"patch": None,
"gis": None,
"covetool": None,
"augin": None,
"debug": None,
"spreadsheet_writer":None,
# Uncomment this line to enable loading of the demo module. Happy hacking!
# The name "demo" must correlate to a folder name in `bim/module/`.
# "demo": None,
for name in modules.keys():
modules[name] = importlib.import_module(f"blenderbim.bim.module.{name}")
classes = [
operator.AddIfcFile,
operator.BIM_OT_add_section_plane,
operator.BIM_OT_remove_section_plane,
operator.ConfigureVisibility,
operator.OpenUpstream,
operator.OpenUri,
operator.ReloadIfcFile,
operator.RemoveIfcFile,
operator.SelectDataDir,
operator.SelectIfcFile,
operator.SelectSchemaDir,
operator.SelectURIAttribute,
operator.EditBlenderCollection,
operator.BIM_OT_open_webbrowser,
operator.BIM_OT_show_description,
#prop.MyItem,
#prop.MyCollection,
#prop.BlenderBIMSpreadSheetProperties,
#operator.MyCollectionActions,
#operator.ConstructDataFrame,
#operator.WriteToXLSX,
#operator.WriteToODS,
#operator.FilterIFCElements,
#operator.UnhideIFCElements,
#ui.BlenderBIMSpreadSheet,
#ui.MyItem,
#ui.MyCollection,
#ui.MyCollectionActions
prop.StrProperty,
operator.BIM_OT_enum_property_search, # /!\ Register AFTER prop.StrProperty
prop.ObjProperty,
prop.Attribute,
prop.ModuleVisibility,
prop.BIMProperties,
prop.IfcParameter,
prop.PsetQto,
prop.GlobalId,
prop.BIMObjectProperties,
prop.BIMMaterialProperties,
prop.BIMMeshProperties,
ui.BIM_PT_section_plane,
ui.BIM_UL_generic,
ui.BIM_UL_topics,
ui.BIM_ADDON_preferences,
# Scene panel groups
ui.BIM_PT_project_info,
ui.BIM_PT_project_setup,
ui.BIM_PT_collaboration,
ui.BIM_PT_geometry,
ui.BIM_PT_services,
ui.BIM_PT_structural,
ui.BIM_PT_4D5D,
ui.BIM_PT_quality_control,
ui.BIM_PT_integrations,
# Object panel groups
ui.BIM_PT_object_metadata,
ui.BIM_PT_geometry_object,
ui.BIM_PT_services_object,
ui.BIM_PT_utilities_object,
ui.BIM_PT_misc_object,
for mod in modules.values():
classes.extend(mod.classes)
def on_register(scene):
handler.setDefaultProperties(scene)
if not bpy.app.background:
bpy.app.handlers.depsgraph_update_post.remove(on_register)
def register():
for cls in classes:
bpy.utils.register_class(cls)
bpy.app.handlers.depsgraph_update_post.append(on_register)
bpy.app.handlers.undo_pre.append(handler.undo_pre)
bpy.app.handlers.undo_post.append(handler.undo_post)
bpy.app.handlers.redo_pre.append(handler.redo_pre)
bpy.app.handlers.redo_post.append(handler.redo_post)
bpy.app.handlers.load_post.append(handler.setDefaultProperties)
bpy.app.handlers.load_post.append(handler.loadIfcStore)
bpy.app.handlers.save_pre.append(handler.ensureIfcExported)
bpy.types.Scene.BIMProperties = bpy.props.PointerProperty(type=prop.BIMProperties)
bpy.types.Object.BIMObjectProperties = bpy.props.PointerProperty(type=prop.BIMObjectProperties)
bpy.types.Material.BIMObjectProperties = bpy.props.PointerProperty(type=prop.BIMObjectProperties)
bpy.types.Material.BIMMaterialProperties = bpy.props.PointerProperty(type=prop.BIMMaterialProperties)
bpy.types.Mesh.BIMMeshProperties = bpy.props.PointerProperty(type=prop.BIMMeshProperties)
bpy.types.Curve.BIMMeshProperties = bpy.props.PointerProperty(type=prop.BIMMeshProperties)
bpy.types.Camera.BIMMeshProperties = bpy.props.PointerProperty(type=prop.BIMMeshProperties)
bpy.types.PointLight.BIMMeshProperties = bpy.props.PointerProperty(type=prop.BIMMeshProperties)
bpy.types.SCENE_PT_unit.append(ui.ifc_units)
if hasattr(bpy.types, "UI_MT_button_context_menu"):
bpy.types.UI_MT_button_context_menu.append(ui.draw_custom_context_menu)
mod.register()
def unregister():
for cls in reversed(classes):
bpy.utils.unregister_class(cls)
bpy.app.handlers.load_post.remove(handler.setDefaultProperties)
bpy.app.handlers.load_post.remove(handler.loadIfcStore)
bpy.app.handlers.save_pre.remove(handler.ensureIfcExported)
del bpy.types.Scene.BIMProperties
del bpy.types.Object.BIMObjectProperties
del bpy.types.Material.BIMObjectProperties
del bpy.types.Material.BIMMaterialProperties
del bpy.types.Mesh.BIMMeshProperties
del bpy.types.Curve.BIMMeshProperties
del bpy.types.Camera.BIMMeshProperties
del bpy.types.PointLight.BIMMeshProperties
bpy.types.SCENE_PT_unit.remove(ui.ifc_units)
bpy.types.UI_MT_button_context_menu.remove(ui.draw_custom_context_menu)
for mod in reversed(list(modules.values())):
mod.unregister()
It seem when I add the classes of the spreadsheet_writer module, blenderbim won't load anymore in Blender. That's why I commented them out. Any idea on how to debug this?
So if I understand correctly you can keep this file like this, remove your commented lines there and add a file named __init__.py in your subfolder spreadsheet_writer with this content :
import bpy
classes = (
prop.MyItem,
prop.MyCollection,
ui.MyItem,
ui.MyCollection,
def register():
# Here you can add your custom props to specific types eg bpy.types.Scene.my_custom_collection = bpy.props.PointerProperty(type=prop.MyCollection)
pass
def unregister():
# Here you should delete your custom props eg del bpy.types.Scene.my_custom_collection
pass
Of course you'll need to populate ui.py, operator.py and prop.py inside your spreadhseet_writer subfolder
-> Sidenote the convention is to write "spreadsheet_writer": None and not "spreadsheet_writer":None (notice the whitespace between : and None
Thanks for your help, still no succes so far.
What I have done:
in ..\AppData\Roaming\Blender Foundation\Blender\3.3\scripts\addons\blenderbim\bim\module\spreadsheet_writer module I have place the following scripts
- __init__.py
- operator.py
- prop.py
- ui.py
in this __init__.py I have placed the following code:
Then I went to: ..\cclaus\AppData\Roaming\Blender Foundation\Blender\3.3\scripts\addons\blenderbim\bim modeule and opened the __init__.py there, I added the space after in "spreadsheet_writer": None,
The file now looks this:
import bpy
import importlib
modules = {
"project": None,
"search": None,
"bcf": None,
"root": None,
"unit": None,
"model": None,
"cad": None,
"context": None,
"drawing": None,
"misc": None,
"attribute": None,
"type": None,
"spatial": None,
"void": None,
"aggregate": None,
"geometry": None,
"cobie": None,
"resource": None,
"cost": None,
"sequence": None,
"group": None,
"system": None,
"brick": None,
"structural": None,
"boundary": None,
"profile": None,
"material": None,
"style": None,
"layer": None,
"owner": None,
"pset": None,
"qto": None,
"library": None,
"constraint": None,
"document": None,
"clash": None,
"lca": None,
"csv": None,
"tester": None,
"bimtester": None,
"diff": None,
"patch": None,
"gis": None,
"covetool": None,
"augin": None,
"debug": None,
# "demo": None,
classes = [
operator.OpenUri,
prop.StrProperty,
prop.ObjProperty,
prop.Attribute,
prop.BIMProperties,
prop.IfcParameter,
prop.PsetQto,
prop.GlobalId,
ui.BIM_UL_generic,
ui.BIM_UL_topics,
ui.BIM_PT_geometry,
ui.BIM_PT_services,
ui.BIM_PT_4D5D,
def register():
for cls in classes:
mod.register()
def unregister():
mod.unregister()
But when restarting Blender I see BlenderBIM, but somehow I broke it.
Can't make a new project
If you're on windows you can go to Window > Toggle System Console, there should be an error printed out there. You can copy / paste it here to troubleshoot it.
@Gorgious
Many thanks! I managed to get it integrated locally with the BlenderBIM add-on on the BlenderBIM tab. I need to refactor the code a bit , clean the mess before making a pull request.
Hey @Coen
I am busy pulling some areas using your spreadsheet writer, brilliant again, but It's not getting the NetFloorArea, out of the Ifc Space? I tried to add it as a custom value as [Qto_SpaceBaseQuantities.NetFloorArea] but with no success:
Blender:
Spreadsheet (no area values except for the windows):
I was looking for something like this or to make something similair myself, just tested it on an ifc model and it works really good!
Only thing I noticed is sometimes the values under base quantities are not the correct values, is there any way to extract the quantity from the element and not from a pset?
Do you have an example? Not the correct value or no value at all? If there is no value at all you could try this:
Nice just tried it and it's working great.
Here's an example:
The NetArea value under BaseQuantities is 0,59m2
The correct value is shown in the quantites tab, an Area of 3,28m2 (Solibri)
Is it possible for you to share your IFC? Maybe @Massimo could shed some light on this...? I have no Solibri, so I can't validate.
Can't share the entire IFC, but I've extracted the object as an example.
Does not open in BlenderBIM for me:
e 1293, in clean_mesh
obj.select_set(True)
RuntimeError: Error: Object 'IfcSlab/BORDES' can't be selected because it is not in View Layer 'ViewLayer'!
Location: C:\Program Files\Blender Foundation\Blender 3.5\3.5\scripts\modules\bpy\ops.py:113
@Pahlawan Btw, if it helps, quantities are just another psets with attributes. The schema says that the pset name should be "Qto_Name BaseQuantities" so for a slab it should be "Qto_SlabBaseQuantites".
BBim can calculate and assign automatically the quantities.
So, regarding your example, is NetArea calculated automatically or is it given in another way (like typed or imported from another software)?
@Massimo said: @Pahlawan Btw, if it helps, quantities are just another psets with attributes. The schema says that the pset name should be "Qto_Name BaseQuantities" so for a slab it should be "Qto_SlabBaseQuantites".
The basequantities are exported from Tekla.
What's your e-mail?
The dependencies of the BlenderBim addon are located in libs/site/packages
https://github.com/C-Claus/BlenderScripts/blob/master/BlenderBIMSpreadsheet/3.3.3/BlenderBIMSpreadsheet333.zip
I'm just curious if this .zip works for Blender 3.3.3
@Coen It seems like it does
edit: this is flippin useful btw, I'm probably going to be using it quite alot over the next month
I've created a feature here for maybe a future pull request to add to the BlenderBIM add-on:
https://github.com/C-Claus/IfcOpenShell/tree/feature/spreadsheet_writer/src/blenderbim/blenderbim/bim/module/spreadsheet_writer
I want to test it locally on my system, but where do I add it the menu/UI to BlenderBIM?
Would like to add it to the BlenderBIM panel like so, clueless on how to. I am looking into ui.py of the other modules.
It just says
bl_category = "BlenderBIM"I thought changing this parameter would work
https://github.com/C-Claus/IfcOpenShell/commit/cc4afd7b39aa37dc3ded5910c74f2b8c8b375c1c
But I think some more work is required.
@Massimo
spreadsheet_writerwhich contains the codeAlsoI looked into this
https://blenderbim.org/docs/devs/hello_world.html
It says
I see this in the
__init__.pyof the demo folder@Coen It's refering to these lines of code
you'll need to add
"spreadsheet_writer": Nonein this dictionary so that it's automatically imported and registered afterwards. You'll also need to add your panel class in theclasseslist instead ofclasses = ( operator.DemonstrateHelloWorld, operator.DemonstrateRenameProject, prop.BIMDemoProperties, ui.BIM_PT_demo, )@Gorgious
Like this?
spreadsheet_writermodule, blenderbim won't load anymore in Blender. That's why I commented them out. Any idea on how to debug this?So if I understand correctly you can keep this file like this, remove your commented lines there and add a file named
__init__.pyin your subfolderspreadsheet_writerwith this content :Of course you'll need to populate ui.py, operator.py and prop.py inside your spreadhseet_writer subfolder
"spreadsheet_writer": Noneand not"spreadsheet_writer":None(notice the whitespace between:andNone@Gorgious
What I have done:
in
..\AppData\Roaming\Blender Foundation\Blender\3.3\scripts\addons\blenderbim\bim\module\spreadsheet_writermodule I have place the following scriptsin this
__init__.pyI have placed the following code:Then I went to:
..\cclaus\AppData\Roaming\Blender Foundation\Blender\3.3\scripts\addons\blenderbim\bimmodeule and opened the__init__.pythere, I added the space after in"spreadsheet_writer": None,The file now looks this:
@Gorgious
It's a cascade of errors, this is just a segment
I think you're missing registering the prop somewhere. depending on where you stored your props you may want something like
in
registerandin
unregister.@Gorgious
Hehe I'm glad you finally made it happen :) You can ping me on github for help in the process, or review when you manage to upload it.
Cheers
@Gorgious
It's available here for review:
https://github.com/IfcOpenShell/IfcOpenShell/pull/2622
Great Job Coen!
Hey @Coen
Blender:
Anything I'm getting wrong with he syntax here?
@Ace
You should remove the brackets and add press the add button once more. Then it will export.
also, on youtube someone asked me if these PropertySets could be saved as a searchset, but doesn't IFCCSV also does something similar?
https://github.com/C-Claus/BlenderScripts/blob/master/BlenderBIMSpreadsheet/3.4.1/BlenderBIMSpreadsheet341.zip
Update of the BlenderBIM Spreadsheet add-on which will work on Blender 3.4.1
Please let me know if it works.
@Pahlawan
You bumped this old thread, the new release is to be found here:
https://github.com/C-Claus/blenderbim_spreadsheet
The idea is this should be integrated with BlenderBIM one day...
Here's an example:
@Pahlawan
nor in BIMVision:
Hello @Pahlawan i tried to open the ifc file you posted and i get this error
Could you send me the entire ifc by email so i can check?
What's your e-mail?
