BlenderBim Beginner Tutorial - Step by Step Project - Part 2 - 2D drafting
2»
  • @Ace
    What in particular hatching info are you looking for @Coen ? Maybe I can help
    I should just name the material concrete and it should pick up the right hatch? Or am I looking in the wrong place?
  • I think that in cases that you have a material layer, you should name the layer set "concrete". It' not possible yet, that I know, to set one hatch per layer
    CoenAce
    I see:
  • @bruno_perdigao is on the money haha. Sorry I didn't get back in time glad you got sorted
    ING_MIGUELYEPEZ
  • Does anyone know this:
    • Is it possible to offset the dimensions when they are small and too close together? Like this:
    • Is it possible to edit the prefix and the digits number for the level annotation?
    • Is it possible to add custom text to the section symbol?
  • Hi @Ace . I have a very basic issue. When I generate a plan view and I press the 'Create Drawing' button the SVG is not shown and Blender crashes and shuts down. The SVG is correctly generated because I can see it in the 'drawings' folder. If anyone knows about this problem just let me know. Thanks.
  • edited October 2023
    Have you downloaded the latest release? If on windows, it might be this bug, that @Moult fixed recently. It was a gnarly one.
    Ace
  • Hey @vbertran
    I think it is indeed the bug @theoryshaw mentioned I'd recommend updating your blenderbim to the latest and see if it fixes the issue:
    https://github.com/ifcopenshell/ifcopenshell/releases
  • hey @theoryshaw @Ace! You where right!I installed today's releases and it works again.
    Thanks!
    Ace
  • Hi. My floor area is set to 13 decimal places. Is there an IFC setting to reduce this? It can't be a global setting.
  • @theoryshaw I'm using 4.2.1 and I don't see the field to enter that string. But thank you. Is this the only way to do it?
  • can someone try modify the size of their bathroom and see if the IFC Space can be regenerated to fill the new volume. When I try, it disappears and creates a vertical line wherever my cursor is.
